Mine does the fog lights instead of the main beam, it is just a case of altering the option of a 0 for a 1 (or the other way around) in the appropriate byte and bit using VCDS. It may also be possible with Carista.Hi all . Soon be a new year ,where did the time go my van still isn't finish !
Any one got ant closer to the coming home function working automatically at night without having to flash the main beam ?.
May be one for the new year .
Happy new year @DaveyB I do intend to change from main lights to fogs , but do you still need to pull back on the light stalk ? , does the main beam flash as well as the fogs or when you pull the stalk back just the fogs ?Mine does the fog lights instead of the main beam, it is just a case of altering the option of a 0 for a 1 (or the other way around) in the appropriate byte and bit using VCDS. It may also be possible with Carista.
I have seen other vehicles that have that, I don’t think I like it - it looks oddthere is a wink option which switches the DRL off for the side which is indicating.
Have you tested it, does it work ?I have enabled it, would have preferred a dimming option.
Works for me too, only with the lights off so just on DRLsHave you tested it, does it work ?
