Cruise Control Retrofit Euro6
Please explain - what light?
Please explain - where exactly in VCDS is no activity?
Do the audio/menu buttons on the right side of the MFSW work?
Please post full unedited VCDS Auto-Scan.
button is uplighting, everything work (right side is ok = next song, volume etc...) only Css button (let side) dont works, i do photos next day
Hello. I do auto scan. I try coding. I have problem.
Now i have instaled mfsw. Volume, next, etc work great. Only css dont work.
When coding In byte is “nothing” =00 works mfsw. When i get
Byte 29 i set 6. = 40
Mfsw stop working.
Can you tell me where is problém ?
Thank you.
Code:
Thursday,30,March,2023,14:26:00:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH002258   License Plate:
Chassis Type: 7H (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 61 69 0B
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXGB)       Labels: 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 00114014433401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_EC2M0TDI03004L906056KA 004003
   ROD: N/A
   VCID: 76E43D9AC95C7DF1C3-8022
No ASAM data for: "EV_EC2M0TDI03004L906056KA" (VN75)
1 Fault Found:
25111 - ROD - Unknown Error Code
          - 00 [047]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 10
                    Mileage: 139172 km
                    Date: 2076.01.13
                    Time: 15:49:57
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 41296000002775
   Coding: 517E4098256284808A77027BA48A21E6780000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCNOTIVN75XGP2 011001
   ROD: N/A
   VCID: 3F8A98BEA6E6FCB9D0-806A
No ASAM data for: "EV_Brake1ESCCNOTIVN75XGP2" (VN75)
No fault code found.
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 03051613470240
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF425BAE16C35B19B-802A
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E0 907 047 AJ    HW: 7E0 907 047 AJ
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaticT5.rod
   VCID: 72EC018AA53461D1EF-8026
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 138160620
   Coding: 7AA8393A0A212012002809742C2B8CD50F80710F60464D60320400230800
   Shop #: WSC 02737 022 744100
   VCID: 2A5CD9EA4564691197-807E
   Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU009051661305718
   Coding: 0400A0
   Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU019051661406149
   Coding: 1400A0
   Subsystem 3 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160002065900016474
   Coding: B0FFFF
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 G    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0011
   Revision: --H06---    Serial number: 28201429400380
   Coding: 118006
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_EPHVA18SKxxx0000 002001
   ROD: EV_EPHVA18SKxxx0000.rod
   VCID: 45868A56C43AA6699A-8010
3 Faults Found:
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [008] - Open or Short to Ground
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 250
                    Mileage: 138993 km
                    Date: 2076.14.10
                    Time: 11:40:59
1112625 - Front Right Parking Aid Sensor
          B10FA 31 [008] - No Signal
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 138999 km
                    Date: 2076.14.10
                    Time: 16:33:21
1112580 - Front Right Parking Aid Sensor
          B10FA 04 [008] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 251
                    Mileage: 138999 km
                    Date: 2076.14.10
                    Time: 16:32:38
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag00C H08 0018
   Revision: --------    Serial number: 003V3000UR6E
   Coding: 000000000000000000000000000000003043
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_IarbaVW10BPAVW12X 001028
   ROD: N/A
   VCID: 3A7CE9AABDC4D991E7-806E
No ASAM data for: "EV_IarbaVW10BPAVW12X" (VN75)
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Component: KOMBI         H03 1104
   Serial number: 00000000000000
   Coding: 140B010300
   ASAM Dataset: EV_Kobmi_UDS_VDD_RM09 A05733
   ROD: N/A
   VCID: 397EF6A6B8C2D289EE-806C
No ASAM data for: "EV_Kobmi_UDS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042205
   VCID: 68D863E29BE89B0141-803C
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 93723 km
                    Time Indication: 0
                    Date: 2045.14.03
                    Time: 15:02:20
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1104
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADC19EA8DE4A91157-803E
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 330B1A73
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75410903001605040460
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000403173457
   Coding: 410D000103000000
   Shop #: WSC 02739 790 00000
   VCID: 326CC18A6DB421D12F-8066
2 Faults Found:
02565 - Trailer; Right Turn Signals (M63)
            010 - Open or Short to Plus - MIL ON
             Freeze Frame:
                    Fault Status: 11101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 132926 km
                    Time Indication: 0
                    Date: 2008.14.10
                    Time: 13:32:16
02566 - Trailer; Left Turn Signals (M62)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 132926 km
                    Time Indication: 0
                    Date: 2008.14.10
                    Time: 13:32:16
End-------------------------(Elapsed Time: 02:47)--------------------------
Reactions: mmi
Mfsw stop working.
Well, try to set BCM byte 17 bit 2 => 1
Thus the byte 17 current coding 80 will change to 84.
This defines CC controls to be on MFSW.
i do it but problem...
- byte 17 i get 2 (84)
- ok
MFSW - ok (only volume, next song, maxi dot) cc nothing
then i get 29 byte to "40" = MFSW dont work, do nothing, not CCS, not volume
can you resend me good wiring? i try chceck wiring, but i dont have "schema" and i dont good understand english
Just double-checking - your van did not have cruise control before?
Did you connect from coil connector T41_pin_10 to BCM connector T73b_pin_36 (white connector)?
dont have CCS
original have only plastic SW
i try it check
i dont have VIP member, i can not download it
Mfsw stop working.
Thank you.
Code:
www.Ross-Tech.com
   Revision: 23002001
   ROD: N/A
1 Fault Found:
          - 00 [047]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 10
                    Mileage: 139172 km
                    Date: 2076.01.13
                    Time: 15:49:57
Readiness: N/A
   ROD: N/A
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: 0400A0
   Coding: 1400A0
   Coding: B0FFFF
   Coding: 118006
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 250
                    Mileage: 138993 km
                    Date: 2076.14.10
                    Time: 11:40:59
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 138999 km
                    Date: 2076.14.10
                    Time: 16:33:21
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 251
                    Mileage: 138999 km
                    Date: 2076.14.10
                    Time: 16:32:38
   ROD: N/A
   Coding: 140B010300
   ROD: N/A
   Revision: B9081001
   Coding: 042205
1 Fault Found:
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 93723 km
                    Time Indication: 0
                    Date: 2045.14.03
                    Time: 15:02:20
   Serial number:
   Coding: 000000
Address 56: Radio
Cannot be reached
   Coding: 330B1A73
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 132926 km
                    Time Indication: 0
                    Date: 2008.14.10
                    Time: 13:32:16
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 132926 km
                    Time Indication: 0
                    Date: 2008.14.10
                    Time: 13:32:16
This combined wiring diagram should be helpful and should eliminate any potential confusion.
@Dusankooo can you clear all of your old faults and do another fresh Autoscan and post it here?
Bad wiring. My friend get cable to pin 17. Cable must go to 36 b In bcm.
I cut new wire. Get In the 36. New coding In byte 29. Everything go perfect.
Now In pin 17 is originál blue/green wire.
New wire is In 36.
Than mfsw dont work. Then i coding byte. 29. Everything now go perfect.
I am so happy. Very Easy work. Only 5h to do.
Thank you very much for your feedback - I think it's really valuable for all of us - to share all the good... and mistakes, too. Learning by doing ;)
Oh, and by the way - Welcome to the Forum!
I've recently bought a T6 shuttle and I'd like cruise control fitted for long journeys. I'm happy to go with the stalk version, is there anybody someone would recommend? Looking at HazzyDayz or Professional Retrofits at present.
Apologises if this has been asked before or if this is in the wrong section.
