Ok - obviously my proposal to disconnect the wire to T36b won't do any goodI wired it with the two repair wires one to t36b and one to the light switch side light feed
Hi, I have this same issues you experienced with fault code u0146, I have factory cruise on the stalk. On 2017 t6 euro 6. Fitted mfsw from a polo with no cc. Did you swap the pins 17 and 36 over or did you just leave original wire that was in pin17 disconnected?So I have moved from pin 36 to pin 17 recoded it and all is good and working with no faults at all I did ask some else today about and they also confirmed pin 36 is for mfsw with cc on and pin 17 is for mfsw with cc on the stalk
Thanks for everyone's input in getting this sorted
Hi mateHi, I have this same issues you experienced with fault code u0146, I have factory cruise on the stalk. On 2017 t6 euro 6. Fitted mfsw from a polo with no cc. Did you swap the pins 17 and 36 over or did you just leave original wire that was in pin17 disconnected?
Cheers in advance.
Have you wired the two new wires for the mfswHi mate I le
Hi mate
I didn't change the anything of the original wiring loom I would imagine if you had cruise control on stalk originally it wouldn't be anything to do with it did you had mfsw originally
I’ve done battery reset nothing. Security code in central electrics? Tried but can’t get the right code for itHad this a few times. Did you enter the security code when you coded the ECU? It's not a must but had a few vans that was funny with it also do a battery reset this often has sorted this issue for me the ECU and BCM don't always seem to like being coded
Pin 36 is for cc on the steering wheel 17 for cc on stalk does the horn workSo I’m trying to add mfsw, added 2 wires from pins 9 to 12v on light plug. Then 10 I went to pin 17 on the bcm white plug, spliced into green and blue wire. Coded nothing worked other than the button lights. Put wire into pin 36 instead and some of the buttons work on the right but not as they should. but still have the u0146 code with eml on.
You definately need a CCS wire from pin 11 to the ECU this is the trigger signal when you use steering wheel buttons without it CCS won't work.So I have done that all bar removing the ccs wire from pin 45. I put pin 26 back to standard as I didn’t think it changed anything but I will try redoing it tomorrow see how it goes. Cheers.
No pin 10 needs to go to pin 17 100% I think there's a coding issueSo I’ve put in pin 9 to 12v and pin 10 to pin 36 of bcm
