volkscraft
Matt
I think all of the connectors are the same, It's more that the BCM firmware or chipset up will be different to support these features.
No. Mines a 2016, but it's a euro 6. The euro 6 engine appeared much earlier in the people carriers, than it did in Kombis and PVs. In fact I don't think there was a euro 5 T6 Shuttle. Existing factory BCM took the cruise without issue. I wanted cruise on the stalk as I didn't, at that time have a MFSW and actually preferred it in this location. I've just retro fitted factory fog lights too. No issue there either. Just plugged straight into the original BCM connector. Here's my BCM if this helps
There is a new VCDS cable that works with 2019 vans.Thanks Deaky, from what I have heard VCDS does not work on 2019 T6's, the seller said it would not be able to do it in the kits description as well.
