Can I now please confirm with you the coding below will be correct for CCS with MFSW on EU6 Diesel Engine, with LIN bus of MFSW connected to BCM T73b Pin 36:
ECU 01:
Set Byte 05, Bit 5
BCM 09:
Set Byte 29, Bit 6
Set Byte 09, Bit 3
Set Byte 15, Bit 0
Set Byte 17, Bit 2
Set Byte 17, Bit 7
ECU 01:
Set Byte 05, Bit 5
BCM 09:
Set Byte 29, Bit 6
Set Byte 09, Bit 3
Set Byte 15, Bit 0
Set Byte 17, Bit 2
Set Byte 17, Bit 7
