CTek D250 battery selection cable query
Brindle
I just saw the below on a Facebook forum and it got me thinking. I’d always assumed the battery selector. Cable referred to the leisure battery not the starter battery. After all how many vans are going to have lithium starter batteries??? Or am I wrong? If it does refer to the starter battery how do I tell if mine is AGM or standard? (2017 T6 204 tdi DSG)
you are correct,
the battery select cable is for the Leisure battery that the charger is charging.
not the vans starter battery.
NORMAL refers to a standard LEAD ACID,
then you have a AGM/EFB+ setting,
then the lithium setting ( on the D250SE, the older SA version doesnt have the lithium option)
