MyfirstVW
Evening all,
Coil light flashed at me today (first time) and i had a loss of boost, i guess it was in limp mode. I came straight home and plugged into VCDS. Any guru willing to nudge me in the right direction regarding where to start faulting this one please? I initially thought boost leak, had a good look around but couldn't see anything obvious. Pulled the following off VDCS before i cleared the DTC's. 2017 CXEB 95k. New EGR / Cooler last year.
Any help very much appreciated
5 Faults Found:
23957 - Boost Pressure Regulation
P0299 00 [01100100] - Control Range Not Reached
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154081 km
Date: 2081.01.29
Time: 15:34:31
Engine RPM: 2435.25 /min
Normed load value: 99.6 %
Vehicle speed: 113 km/h
Coolant temperature: 92 °C
Intake air temperature: 25 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.039 V
Unlearning counter according OBD: 40
Charge air pressure: specified value: 3.587 bar
Absolute intake pressure: 255 kPa abs
Mass airflow sensor 1 bank 1 airflow: raw value: 1450.5 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.67 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Turbine actuator 1 bank 1: posit.feedback - Actual value: 19.91 %
Mean injection quantity: 86 mg/stroke
Air cleaner degree of soiling: 11.45 %
Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value: 2916 mbar
Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Actual value: 7.29 %
25960 - Boost Pressure Regulation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154081 km
Date: 2081.01.29
Time: 15:34:31
Normed load value: 99.2 %
Charge air pressure: specified value: 3.585 bar
Mass airflow sensor 1 bank 1 airflow: raw value: 1454.7 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.17 %
Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value: 2909 mbar
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [01100000] - Efficiency too Low
30540 - Throttle Position Sensor (G69)
P0121 00 [00100000] - Implausible Signal
16230 - Control Module for Instrument Cluster
U1019 00 [00100000] - Missing Signal for Oil Level/Temperature
[Instrument cluster control moduleMissing signal oil level/temperature]
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154081 km
Date: 2081.01.29
Time: 15:34:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154081 km
Date: 2081.01.29
Time: 15:34:31
