Hi all
I am currently rebuilding my CXFA engine that has two balance shaft’s built into the engine block. I have not been able to find any information as to the position they need to be in when I install the crank shaft. When the block is upside down on the engine stand the shaft‘s rotate to the heaviest side facing the floor. I just want to be sure I don’t need to position them in anyway before bolting everything together as they connect directly to the crank shaft.
I have the VW engine build manual but the only reference it makes to the balance shaft’s is on an exploded engine block diagram simply states this diagram does not cover engines with balance shaft’s!
Any help would be greatly appreciated
