Hi,
I'm hoping for some advice/pointers regarding my 2017 VW T6, which has a 2.0 litre diesel engine with 107,000 miles on the clock. I recently put the van into a trusted local garage, as the engine warning light came on. The mechanic ran a diasnostic check and it threw up four codes. One of them was P13D600 (sensor for internal pressure of cylinder 3 implausible signal). He said he could sort out the other codes, but not the one above. He told me he had a van in with the same code last year and after investigation, a bent conrod was the cause of it, so he advised me to book my van into main dealer for further investigation. I did this and was told by the VW mechanic I needed a new pressure sensor, which cost £315. After
giving them the go ahead they got back to me saying the engine warning light was still on and that the fault must lie elsewhere! I then paid for an extra 2 hours labour (£240) for further investigation. Was told compression is down on all four cylinders and its looking more likely to be internal damage...possibly a bent con-rod. Now they tell me they need to take the cylinder head off and investigate internal engine parts, which is a further 7 hours labour charge = roughly £1000 !!! They also told me the engine may need replacing altogether.
107,000 miles on a 2017 T6 with full VW service history and it's looking highly likely that the enfine is kaput!!!! Surely that kind of engine life expectancy can't be right. VW said they'll contact their warranty people to see if there's anything they can do re:goodwill, but I'm not too hopeful. Has anyone else had a similar experience? Any advice/pointers will be most welcome. Thanks in advance!
