DAKU'S VAG CONTROLLER for PQ25
And another function :thumbsup:
But not the last one :whistle:
When DPF regeneration process begins Instrument Cluster does the following:
- sounds the gong
- displays text message "DPF Cleaning In Progress !"
- starts to blink DPF LED
And when DPF regeneration process is finished Instrument Cluster does the following:
- sounds the gong
- stops blinking of DPF LED
Below is my another show off video ;)
- sounds the gong
- sounds the gong
Robert! Stop teasing us mate! :p
Any chance Santa can get a few modules for shipping? :thumbsup:
Great stuff!! How does this unit compare to ColorMFA/ColorMFD? (for T6 this is out of question as ColorMFA doesn't support it), but for T5 it will be hard to beat ColorMFA functionality.
Are you referring to Instrument Cluster type as per below?
T6 Instrument Clusters
Hi Robert,
I am comparing to 3dcolormfd — Цветной дисплей для приборной панели or the equivalent ColorMFA system, which unfortunately is only availble for T5 up to 2010. I would happily swap my "stone age" MFD Plus to the ColorMFD if it was compatible... :-(
T5 (2003-2009) uses KWP as an Instrument Cluster communication protocol
but T5 Face Lift (2010-2015) & T6 (2016-2019) use UDS.
@Daku's controller has been originally developed for TP protocol
and thanks to @dnoermann's involvement
I have the privilege and the pleasure to demonstrate results of the hard work taking place behind the scenes.
when, when, when can we buy it... :D
do you need a beta tester/translater for german language?
Send direct message to @Daku and ask the question :thumbsup:
Haha, I contacted @Daku before and wanted to buy his PCB board. However, due to regional reasons, the freight is too expensive. So I gave up.
I just want to realize the green light on the dashboard of the running ACC and the green light on the lane
This is actually the functionality that I am just about to present :whistle:
Front Assist - green LED &
Side Assist - green LED
to be specific.
@hanzz I'm working about my module create audio menu if radio didn't send it, it can got some bugs like now on bench, but menu is accessible :)
absolut great! Thank you!
As already said, if you need a beta tester or german translator please pm me :D
to be specific.
Its strange that T5.1 side assist green led light was on in my OEM cluster, but when I changed to T6 it didn’t
