Tuesday,20,December,2022,20:57:51:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZGH059472 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 14 15 17 18 19 25 3C 55 5F 61 69 0B
VIN: WV2ZZZ7HZGH059472 Mileage: 147640km-91739miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KM HW: 04L 907 445
Component: R4 2.0l TDI H02 6186
Revision: 23002001
Coding: 0019401C434401080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
ROD: EV_ECM20TDI03004L906056JS_004.rod
VCID: 020B3F0F950F189605-8056
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 42785000000617
Coding: 307E4098256784870C79027DA48421D378F500
Shop #: WSC 02739 790 50316
VCID: 3F8DF6FBA67DB57E2A-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 15101513470638
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7661-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 HW: 7E0 907 040
Component: ClimatronicT5 H02 0508
Revision: 00001K03
Coding: 0000000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 60CF15877B43AA8673-8034
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0011210150015264
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 293150658
Coding: B8A039BA0A61349293284F606CEB87D4C0A4738960CD79603204003F0860
Shop #: WSC 39775 001 104857
VCID: 68DF0DA79B73D2C6BB-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 301015 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU023091552661013
Coding: 0400A3
Subsystem 3 - Part No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU023091552666639
Coding: 1400A3
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 171
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29150001904400125393
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 N HW: 7N0 919 475
Component: PARKHILFE 8K H06 0205
Revision: -------- Serial number: 28261523300304
Coding: 318009
Shop #: WSC 93651 188 12345
ASAM Dataset: EV_VW75XParkAssis8K 001007
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 3D718CF3AC71A76E38-8068
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 A HW: 7E0 907 572
Component: ACC Bosch PQx H03 0110
Serial number: 25091577091664
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001004
ROD: EV_ACCBEGVW361.rod
VCID: 3467A9D79F3B6626C7-8060
Address 14: Susp. Elect.
Cannot be reached
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00A 008 0016
Revision: -------- Serial number: 003PJ000NGKK
Coding: 000000000000000000000000000000003041
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 387F9DE783538246EB-806C
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB40673FGI6N8I3
Crash sensor for side airbag: front passenger side:
Serial number: 3505ZRB405V3FGI6BH1+
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 880 L HW: 7E0 920 880 L
Component: KOMBI H05 1008
Serial number: 00000000000000
Coding: 170F010400
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3365AACB9A35611EDE-8066
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 HW: 7E0 963 273
Component: STH-T5GP2 002 0007
Coding: 4001
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 6ADB77AF8D7FE0D6AD-803E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 04220D
1 Fault Found:
00471 - Control Module for Elect. Regulated Dampers (J250)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 147647 km
Time Indication: 0
Date: 2017.05.12
Time: 20:51:38
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7E0 907 566 C HW: 4H0 907 566 F
Component: SWA Master H07 0030
Serial number: 0383721776
Coding: 030311
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VN75.rod
VCID: 306FA5C76B235A06A3-8064
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 7E0 907 568 C HW: 4H0 907 568 F
Component: SWA Slave H07 0030
Serial number: 0383620758
Coding: 030311
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0FC2020001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A7B87EFBD5F90561D-806E
1 Fault Found:
13705473 - Databus
U1121 00 [137] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 147647 km
Date: 2022.12.20
Time: 20:51:36
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 D HW: 5K7 035 200 D
Component: MU-S--ER H22 0245
Serial number: VWZAZ2R8945926
Coding: 06570000FF00000011110001000808001F0100D40020010003
Shop #: WSC 14824 003 104857
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2541449324E10FAE40-8070
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 330B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 62271C45361261750521
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000382508708
Coding: 410D000103000000
VCID: 326BAFCF6D2F6816D5-8066
End-------------------------(Elapsed Time: 04:10)--------------------------
