Direct TPMS Retrofit
I have retrofitted a color T6 cluster but It shows the outline
That is Fantastic !
So that Cluster
Part No SW: 7E0 920 880 S HW: 5E0 920 880 S
Component: KOMBI H04 1105
Serial number: 00000000000000
Coding: 140A230C00
Together with that TPMS
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Is bringing Outline.
Need to figure out why the 1105 Cluster i tested did not show outline ....
Forensic Investigation did Prove that this is no T6 SW running on your Cluster.
It is probably the last T5.2 (GP) Cluster PCB with 3D Display inside that Cluster, which simply got the eeprom Changed to a T6 Cluster eeprom.
You can see it in the detail of the Tailgate, on that Picture you see the Teailgate of the T5.2, T6 Tailgate is different.
Wonderful research Dennis :thumbsup:.
I obviously must have custom picture of my own bus as a TPMS outline :whistle:.
hi
I have a t6 (68 reg)
got the sensors intalled (4x 3AA907275F) at a tyre shop
got an auto electrician to install and wire the tpms module (3AA907273F) to the BCM (he checked he could see the module on CAN before putting back the dash plastics)
the cluster shows the car outline, but no pressure data
i went for a drive, never managed to get any data, even tried to zap them with magnets as it seems some are put in learn mode like that)
what am i missing?
I've ordered VCDS but won't get it till Tuesday (both for debugging and creating the wheel/tyre profile)
Direct TPMS system has to get the readings/data from all sensors and recognise their locations(FL, FR, RL, RR) first and then it will display the readings in the IC.
How long was your drive?
Reactions: mmi
Where exactly is your receiver installed?
Photo?
Reactions: mmi
So you have 2 options.
1. At least one of your sensors is faulty or its battery is dead - system won't work at all.
2. Try your receiver at different location and different positioning.
By the way, sensor battery suppose to last for 7 years but a lot of sellers and buyers don't pay attention to that.
Sometimes you can buy a brand new sensor/s with fairly old battery(therefore nearly dead one).
Above is my spare one purchased recently which turned out to be May 2018 so already 3 and half years old.
Reactions: mmi
I didn't check the battery sticker before they went in the wheel. i think they were made in 2016, i'll look for picts i took. i wanted to make sure they were the exact same part number as people here have used.
I'll order a TPMS scan tool. they had no stickers.
But manufacturing date should be stamped on them.
Reactions: mmi
27/09/16. should still have some life in them
originally 1 of the 4 didn't have same date and appear used. so i complained and got replacement one that appeared new and same batch
I wish I was wrong but I really suspect that your sensor batteries are dead(or at least one of them).
TPMS reader or set of fresh sensors will solve your problem.
Reactions: mmi
sounds like you're probably right. thanks. now either vcds or the tpms tool can help identify which. any recommendations for a tpms scan tool?
received vcds
wonder if it could be this:
Tuesday,23,November,2021,17:13:53:42995
VCDS Version: Release 21.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 19: CAN Gateway Labels: 7E0-909-901.clb
Control Module Part Number: 7E0 909 901 HW: 7E0 937 090 D
Component and/or Version: GW-K-CAN TP20 H82 0762
Software Coding: 042305
Work Shop Code: WSC 07856 123 33730
VCID: 6882D1503279A47B0F1-803C
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
it does show ok for the tmps i think
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273 _
Component: RDKBERU30 H02 0011
Serial number:
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 3720422C2FC7FB8356B-8062
No fault code found.
i know why doesnt work 4u ,
You have to added all sensors ID manual and match with each wheel .
so read ID of all your sensors .
go to 65 / adaptation / add ID of your sensor and add which wheel is it . done .
ignition off 10sek and back on
again go to 65 / adaptation / add ID of your next sensor and add which wheel is ..
do that 4 times
so after that your module will c all sensors check picture .
Now do calibration in 65 module / basic settings
i dont have a special tool so i use strong magnet
pickup of list calibration tyle 01 and go to 01 wheel with magnet
30sek , pressure icon will flashing on speedometer click stop
type 02 and go to wheel 02 and do the same .
03 and 04 and go for drive .
i had the same problem
take me few days to fine solution , and now one can help
all people said , that easy , just work strait . (NO DOESN'T ! )
if you have MODULE used or new with new sensors we have to added to each wheel in adaptation . :)
Do that and will work 4 you.
All the best.
I try to enter the id of each sensor but after cutting 10s it is still the same sensor that remains?
help
WARNING !!!
DO NOT BUY FROM THIS
ALIEXPRESS SELLER !!!
YiShuo Professional Auto-parts Store
He/she sells sensors with dead batteries.
I know that the price is tempting but please don't risk and don't waste your time and money.
