This is what I have managed to gather so far.
It might be helpful to other people who want to verify Direct TPMS compatibility.
7E0 920 870 S H03 1107 @mmi
7E0 920 880 S H04 1105 @dnoermann
7E0 920 970 S H03 1107 @Deaky
7E0 920 970 S H03 1104 @StudleyGlass
7E0 920 ?70 ? H0? 11?? @Plumbwise (can you provide missing info?)
7E0 920 980 L H05 1008 @Robert
And I am the only one who is missing vehicle outline in the IC display.
What does the 38.0 between the wheels indicate?Boom! All working. Once I'd fitted the correct sensors, it all burst into life after about 200 yds.
Very pleased with this mod. Many thanks to @Robert, @Deaky, @StudleyGlass, @mmi, @dnoermann for a fantastic, well detailed thread, and the support when I was struggling earlier.
The pressure the tyres are supposed to be set at. You get another menu to pick the tyre size and van loading, it then sets those to the appropriate value, and brings on a warning lamp if low pressure is detected. There's details of the ECU data file a few pages back to customise these. I'm running 20s at 3 bar, so need to create that option.What does the 38.0 between the wheels indicate?
No it won’tHi,
With a van on the way in a few months, I'm looking at wheels. On the LK performance website there is the possibility of buying wheels with TPMS sensors. Will my dash automatically see these readings so I can monitor the individual tyre pressures? I didn't order TMPS as a factory option.
All the info you need is in this thread.Hi. In my T6 from 2018 I have, I can say, an indirect TPMS. I can only set the tires pressure that it is ok and get the waring that it has decreased. Any idea what hardware upgrade my T6 needs to have a direct TPMS? thx for your comments.
Ideally all 4 wires need to be very similar length as you should connect CAN near the BCM and power at the main fuse board.
You can enter through the grommet behind LHS rear lamp.
If it’s a negative wire you could take it to the chassis ?
