you tried pressing and holding the button? did you do a hard reset?
can you switch on the HRS via VCDS @mmi? as a bi-directional control test?
so are we saying its a coding problem some how?
Supply fuse ok,
switch seems to be working,
BCM sees switch,
BCM sees HRS when disconnected and raises fault,
5v loop power at HRS,
good ground at HRS,
so it should be working . . . . . unless the programming is not enabling it to function?
Supply fuse ok,
BCM sees switch,
good ground at HRS,
