Ah. Not good.I believe the relay is inside the BCM so always located under steering wheel
Not sure they would even do mine under warranty, in the first month of ownership I added an extra wire into the bcm to add a door locking switch to the driver's door which it didn't come with.No not ideal if that is the issue but not overly taxing for a dealership to replace
Yes, when the heater element is disconnected - there is a kind of 5.7 V on the left connector. Actually it seems to be a pulsed signal at 200 Hz - need to have closer look into using a scope. Anyway, the important part is that a regular multimeter shows 5.7 V. I think this suggests that the +feed wiring is connected all the way up to the BCM.might be worth checking yours @mmi to see if you get the same 5v reference voltage at the HRS when the wires are disconnected (cable disconnected means no current flow, so no volt drop, so the 5v should be present on the +12v switched live).
(we know his BCM is detecting if the HRS is disconnected as it reports back a LIVE fault that clears when the heater is reconnected)
Based on a quick try the tests work as advertised.Interesting, you can do output tests with VCDS to activate all functions in the T6
You could try doing an output test on the button light to confirm it activates and stays on then you could also do an output test on the screen itself and see if it warms up (dont think it will light the button for this though ?)
The engine was not running?heres my output tests, (Base battery load was 10A"drive current"(that would be coolant pump, DRL`s, BCM ignition etc etc)
HRS Z1 - which i dont have (no relay click heard and no additional battery load)
152747:
Heated front screen Z2 - (no relay click heard and 38A additional load on battery)
152810:
Heated external mirrors Z4 & Z5 (relay click heard at the BCM location, additional 6A battery load)
153033:
so no obvious relay action on the front screen.
No, it seems the VCDS output test function forced the function regardless of the engine not running.The engine was not running?
@andys any chance of a picture of your current BCM byte15 settings?just for giggles here is mine:
i have heated front screen and heated side mirrors, but NO REAR windows or HRS.
BUT bit2 is SET on mine !
so mine is "74" = "0111 0100"
View attachment 38335 View attachment 38336 View attachment 38337
While @andys was out compared codings of 08:HVAC and 09:Centr.elec with mine. A difference was "the connection" with mirror heaters and rear heater. But that shouldn't be an issue...
Confusing part is the mysterious, steady 5.7 Volts. If that voltage would really exist across heating element that would mean 10 Amp draw... trying to think how loose/broken cable on either on +feed or ground side would cause that... because it looks like the van tries to fire up heating but detects something... not enough current draw?
- Have you measured resistance from ground to right connector (or silvery strip in the element next to) - should be less than 0.1 ohm.
- From ground to left connector (or silvery strip in the element next to) - should be about 0.5 ohm.
- From right to left connector (heating element) should be the same about 0.5 ohms.
The above would just verify that the heating element is ok. And basically grounding...but...
Bypassing factory ground wire in the loom could be done by a separate parallel wire from right connector to proper ground... to see if it works then...
And tailgate closed - I'm not sure if that would make any difference...
Interesting, don't know - never looked into tests in this area - yet![]()
So even though you have no HRS the BCM was still happy to run the output test whereas on mine it came up with "Inactive"!heres my output tests, (Base battery load was 10A"drive current"(that would be coolant pump, DRL`s, BCM ignition etc etc)
152747:
152810:
153033:
Just so happens I have one right here@andys any chance of a picture of your current BCM byte15 settings?
I don't have one. Yes I have tried ticking and unticking all of the options in this byte but nothing made any differencewhy is the "heated front screen" not ticked?
this is my readout.
I think we're time travelling due to editingwhy is the "heated front screen" not ticked? have you not got one?
have you tried ticking it anyway? - possible shared source from the BCM.?
LOL - - - - -I think we're time travelling due to editingMy answer is in the post before you ask it
I haven't tried the output test with it ticked, but it didn't make any difference to the HRS when I tried it.LOL - - - - -
have you tried ticking it anyway? and retest the switched output functions?
