allupstairs
@Loz I've been told that the drivers door governs both window winders. Do you know what the part that is damaged is called, also where can I get one.
The motor appears to work fine, I'm guessing change that part and if possible the male block connection block to it as that terminal is damaged.
Would you think that would then fix the issue?
TIA
TIA
