Engine Check Light - T6 2018
Boshthebutcher
Hi, any advice appreciated
In the heavy rain the other day, I was driving on the motorway when the engine check light came on.
I’ve given it a good run, thinking it was the DPF, which didn’t sort it.
So I have brought an OBD Wi-Fi dongle and have scanned for the DTC and came up with a few errors.
I’m certain it’s due to the rain. I’ve cleared it the below code and the light has gone off, but comes back on a for a few hours later.
I was going to check the sensors on radiator and give them a clean?? Could this sort it, or should it be a trip to the garage??
The stop start battery has also stopped cutting off.
Thanks in advance.
P2185
Raw code: 2185
ECU: Engine control unit
Status: Confirmed
Engine coolant temperature (ECT) sensor 2 - circuit high
Full scan below:
Car Scanner ELM OBD2
DTC report
Selected brand: Volkswagen
VIN: WV1ZZZ7HZJH071155
============1==============
P2185
Raw code: 2185
Status: Confirmed
============2==============
27230
Raw code: 006A5E
ECU: 01. Engine control unit
Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear
P164E00: Oil pressure regulation valve, Electrical error
============3==============
16106
Raw code: 003EEA
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
P218500: Engine Coolant Temperature Sensor 2 Circuit High
============4==============
27230
Raw code: 006A5E
Status bits: 1
Priority: 2
Frequency: 3
Unlearning index: 255
Odometer: 105320 km
Date, time: 2014.01.19 09:27:40
Engine RPM: 1987 rpm
Calculated engine load value: 38.04 %
Vehicle speed: 15.5342798059333 mph
Engine coolant temperature: 81 ℃
Engine oil temperature: 21 ℃
Barometric pressure: 99 kPa
Klemme 30 voltage: 12
Paramteric values: 20 96 28 20 4C 03 0E 20 2F 0D D9 20 A3 03 44 54 00 AF 44 D2 00 D7 02 8D 01 38 20 97 00 06 44 D0 06 B6 20 3F 0B 27
============5==============
16106
Raw code: 003EEA
Status bits: 1
Priority: 2
Frequency: 20
Odometer: 105314 km
Date, time: 2014.01.19 09:15:02
Engine RPM: 898 rpm
Calculated engine load value: 24.71 %
Vehicle speed: 11.184681460272 mph
Engine coolant temperature: 62 ℃
Engine oil temperature: 16 ℃
Klemme 30 voltage: 14
Paramteric values: 20 96 28 3F 65 01 44 44 C9 0C B8 44 D0 00 00 44 54 00 7D 44 7F 03 E8 44 80 00 00 44 D2 00 B4 44 9C FE 70 70 EB 00 00 20 4C 00 07 20 2F 0C F0
Thanks again.
**SOLVED** DTC P2185
It was a frayed wire going into G83 Temperature Sensor.
The wire hadn’t snapped and was still attached but must have been shorting. I put some insulation tape round it and put it back together and all good so far.
The fan is not coming on now from cold and the start stop on the engine works now with no errors.
Reactions: mmi
