Fault code P003C(C8)
carlg
204 DSG Highline Kombi MY23
T6 Legend
Just scanned my van and have this fault code P003C (C8)
Intake camshaft profile control A
Any one had this fault, is it an easy fix?
Is this a T6? Did you get a dash warning light?
What's the connection profile of the scanner (under Settings)?
Please try OBD-II/EOBD Diesel DPF var. 1 (and/or var 2. or var. 3) - under Volkswagen. I have been using var.1 which seems to work quite well (=results match with VCDS).
Hi
Yes a T6, no warning light.
But van has been stalling after putting in gear and letting the brake off, then slightly hesitates to set off once started again
Thanks.
Got curious because the codes on the screenshot are a bit strange for T6 - they are just generic OBD II codes and missing are corresponding VW specific codes.
Please try connection profile OBD-II/EOBD Diesel DPF var. 1 (under Settings... Volkswagen...) and read the codes again.
Please post also calibration ID (on main page after connecting to ECU) - a string starting 03L or 04L.
Hi
It was only done with a odb and phone app. I don't have access to any other device.
Van booked in at vw next week
Yes, the "instructions" above are specifically for your phone app (Car Scanner - Free version) ;)
