All pull bottom to top other than the sliding door for some reason. The barn doors are obviously this way because the bottom of the window is wider than the top but not sure about the others to be honest. I'm sure I read somewhere on this forum before the reasoning behind it but cant remember. Not sure if it had something to do with my drivers side window being a slider or not.Great looking van you've built!
With the Swell Shades - is there a reason one looks like it pulls top to bottom, and one is bottom to top?
Hello, where is the flooring from?This weekend was spent modding my vanfurniture sliding bed so it sits flush with the rear door so I get the maximum space for entry/exit on the sliding door. Its all held securely down with these threaded screws i found. Great for being able to easily remove the bed without leaving anything protruding from the floor. Once that was all sorted the altro was glued down. Also mid process of making a sliding tray for my bike. The logistics are a lot harder than I thought when I took into account I still wanted to be able to use the bed at full width without removing the tray.
It's altro flooring mate, think it's called veteran oak. Should be able to find it onlineHello, where is the flooring from?
Its about 1200 but in theory you could make it narrower or slightly wider depending on how far you slide out the extending bed section. I did consider the L shape but because i wanted to leave a space down the middle for when i have my bike in it wouldn't have worked. When the bikes not in i usually just leave the rear section out so its like a L shape anyway as it works best for eating off the table.This is the sort of arrangement I'm looking at.....very nice work!
What is the total width of your bed, 1100, 1200?
Did you consider the L shape from Vanfurniture?
I dont have one on me but i'll try and remember to take one when i get home. I had to fashion a new side piece out of a similar ply as with the door open there was a gap as the bed has a cut out for the wheel arch which is universal for different vans so extends further than you may want. I also shaped mine so it sits flush with the rear door meaning i get the maximum space for going in and out of the sliding door. I'd say you gain loads of extra useable storage with these beds as well compared to a generic rib bed not to mention how much cheaper they are. It was a no brainer for me considering i wasn't going to have passengers in the back when driving around.looks good! do you have any photos of the bed looking in from the side door .Been looking at these beds but cant visualize how much space I might gain over a RIB bed
Cheers for that .I actually have a RIB bed fitted at the moment but would like to free up some more useable space inside for sitting .Its a great bed but find it a bit restricted at night if no awning attached. What length did you get ?I dont have one on me but i'll try and remember to take one when i get home. I had to fashion a new side piece out of a similar ply as with the door open there was a gap as the bed has a cut out for the wheel arch which is universal for different vans so extends further than you may want. I also shaped mine so it sits flush with the rear door meaning i get the maximum space for going in and out of the sliding door. I'd say you gain loads of extra useable storage with these beds as well compared to a generic rib bed not to mention how much cheaper they are. It was a no brainer for me considering i wasn't going to have passengers in the back when driving around.
makes sense. I went for the 1800. I could measure the gap between the b pillar and the edge of the bed if you want? Just as i know some people are worried about it encroaching on the space to get in/out of the sliding door. Mines is a SWB so if you have a LWB it would be more than enoughCheers for that .I actually have a RIB bed fitted at the moment but would like to free up some more useable space inside for sitting .Its a great bed but find it a bit restricted at night if no awning attached. What length did you get ?
SWB too a photo will do great when u get time (no rush) .Will be interesting to see as you have the same evo units as me as well!!makes sense. I went for the 1800. I could measure the gap between the b pillar and the edge of the bed if you want? Just as i know some people are worried about it encroaching on the space to get in/out of the sliding door. Mines is a SWB so if you have a LWB it would be more than enough
Yeh its pretty decent. As spacious as you're going to get with this size of van I guess@Davidh thanks for that looks quite spacious
Like it.@stu3467 this is how I usually leave mine with the back half out unless I've got the bike in there. It leaves me with 600mm from the b pillar to edge of the bed for getting in/out which I find is more than enough
Not sure if you can see in that pic very well but its nothing too structural. Just really following the contour of the rear corner. There is a vertical support underneath that I had to move forward a bit but other than that it wasn't too difficult. It's worthwhile to do as it does gain you quite a bit more space.I think you said you did some alterations to the bed to get to sit flush to the back door? Was it structural or just a bit of scribing? With it being 1800mm, I'm guessing it gives you a little bit more room by the slider....
Who did your cushions?
