Wait till sunday..I thought being 'fish' you would know all about water quality and tanks
Ok I'm off to count my micro fibers![]()
You can unscrew the cap and then place it back on with just the first turn.but if you leave the drain open, which on my tank is a large screw cap, there is the possibility to have mices climb in and nest, you wouldnt know until the drowned carcass blocked the tap or dropped out on the next drain....![]()
Not if it is a sealed tankYou can unscrew the cap and then place it back on with just the first turn.
You are trying to ensure the water tank remains bone dry so as to eliminate any risk of Legionnaires. If the screw cap is on loose it will allow a flow of air to keep it dry but not allow any rodents to get in. Also keep the drain hole open slightly.
Showing your blue-hole @Fish![]()
In more ways than one.. but I think some members should come with warnings of influenceMaybe this thread should carry a warning.
Reminded me to check my add blue today, stop me putting the cap on passenger step now
Look closer at this image.Me no understand...my adblue is underneath the diesel filler..
That needs a brush in there pal.I use mine for thisView attachment 40110
That needs a brush in there pal.![]()
You must go to the same guys as @Lord MfwicI will have a word with the Polish yard brush wash brigade next time they valet it for me![]()
