Nah mate.. she didn't have my tea ready when I got back home... and only cooked 8 pancakes for me.. whats that all about!!. Joke..Has she found your forum thread with everything on it??
Busted.
Another QQ on your water setup.... where do you have your inlet? I assume it needs to be above the tank so must be somewhere clever as I doubt you have it plonked on the van's side?!Being push fit connections I swap from a whale inline pump to a submerged pump in a container.. this 'will' (not done yet) plug into a screwcap 12v socket on underside of van behind side bars.
Mine is in the rear, behind an Internal panel. I didn't want an outside one nor did I want it visible.Another QQ on your water setup.... where do you have your inlet? I assume it needs to be above the tank so must be somewhere clever as I doubt you have it plonked on the van's side?!
It is filled with either a hozelock type or submersible pump(for cleaning or on site using a container?. Best of both worlds.
Not really it is below fill point really, rely on the pressure to push the water to the tank till fill on gauge.That makes sense. I didnt think youd defile your van with a huge port on the side!
I guess you have the fill port up fairly high to allow downward flow to the tank?
I always drain mine completely when not in use and leave the waste tap open, stored water = bacteriaOn another note, really not sure if the tank should be left empty or partially full, when not in use.. Bert is used daily so water would always be moving in the tank etc.. but is this right or wrong..
Motorhome man?? @Tourershine
Travel veteran?? @Davenjo
We always drain down if not going to be using the water for more than a couple of weeks.On another note, really not sure if the tank should be left empty or partially full, when not in use.. Bert is used daily so water would always be moving in the tank etc.. but is this right or wrong..
That's true, and I did get mice in through the Truma vent in my T5. Not happened to the T6 yet and I live surrounded by fields, then again the T6 fits in the garage because it's SWB and the T5 wasn't.but if you leave the drain open, which on my tank is a large screw cap, there is the possibility to have mices climb in and nest, you wouldnt know until the drowned carcass blocked the tap or dropped out on the next drain....![]()
