Hi,
Below I thought I would try to summarise what I believe to be the current position of the vehicle:
EU6 2016 Startline - no factory cruise stalks or MFSW, CXHA 2.0 TDI with stop/start and adblue.
T6 compatible MFSW fitted with correct switch part 7EO959442.
Prep work:
GRA wire from pin1 ECU to pin 11 on stalk adapter
Pin 10 wire to BCM pin 36
Pin 9 to light switch for +12v
Blue white horn wire to missing wire on black connecter behind wheel so horn now uses LIN
Both brown earths merged for ground
Coding:
Standard CCS enabled in ECU (non-adaptive)
ECU01:
Byte 05, bit 5 to tell ECU CCS fitted
BCM09:
Set Byte 09, Bit 3 for MFSW fitted
Set Byte 15, Bit 0 for wireless phone
Set Byte 17, Bit 2 (not sure what this does)?
Set Byte 17, Bit 7 advise BCM CCS is fitted
Set Byte 29, Bit 6 to advise pin 36 for MFSW LIN Bus
Error:
25110 - Cruise Control System Switch (E45)
Error P0568 00 [039] - Implausible Signal
Issue:
Cruise system I assume disabled due to error - no error on MFD in dash, no option for cruise on MFD, no response from any cruise buttons.
Wheel builder assured all buttons including cruise tested before dispatch.
Troubleshooting:
- Cleared codes, recycled ignition
- Installation double checked
- Checked pin 45 on bcm for conflict (nothing installed on this pin anyway)
- VCDS shows all CCS buttons being pressed when checking live data
So I am at a loss as to where to go from here?
Any help or advise appreciated, as I’ve already spent over a small fortune on this single mod (including wheel etc) and cannot continue to throw money at it, but would love to get it working so I don’t have a bad ankle on every long journey
Any help would be really, really appreciated.
Many thanks.
Prep work:
Coding:
ECU01:
BCM09:
Error:
Issue:
Troubleshooting:
Many thanks.
