Just to clarify - you did drive the van and tried to engage the CC?Done and as much as I’d like to say it worked it didn’t unfortunately, thanks anyway.
I'm assuming the fault memory was not cleared after battery disconnect (shouldn't make difference but...)Hmmm. Not the out come I'd hoped for. Any more ideas @mmi ?
On first page of this thread is a mention of "dirty" +12V feed causing the same faultHmmm. Not the out come I'd hoped for. Any more ideas @mmi ?
The stalk CCS kit I used got a +12v from a large wire near the BCM which caused it to give a fault now and then but stopped the CCS completely with the MFSW. When the ignition was turned on the buttons all worked OK but as soon as the engine was started the CCS would show the exclamation mark in the display. The ECU also had an error code - Implausible signal on CCS. On testing I found there was a 3v pulse coming back to the +12v wire when the ignition was turned off. As there was no load on this wire the 3v was not clamped down to ground. Once I moved the wire to the light switch connector black wire all was OK.
Although the light switch is fed directly from a fuse - perhaps a try to feed (temporarily) e.g. from cigarette lighter socket - just to eliminate that one.I wired pin 9 on the steering wheel to the black on the headlights switch
Yeah no problem with that buddy. We'll get you sorted one way or the other. I need to get to the bottom for my own piece of mind.Thanks guys for continuing to try and assist!Appreciate forum members who have stepped in massively and credit to Dav-Tec for clearly supporting customers way beyond any initial work.
Basic clocks - not sure, I read somewhere om the German forum that non or basic-MFD it still works, but may not show in cluster. I assume mine should, as I have temp, speed limit, trip 1+2 , mpg etc, I don’t believe I have speed, but maybe that isn’t a more fancy MFD but coded?
I drove over 40mph and tried all CCS buttons, no display changes, no error in MFD, just like they weren’t even there. I ‘think’ if a fault registered in memory perhaps it disables system?
I’m between finding a family member with an android device and getting obdeleven to clear codes in diff modules and check live data etc or maybe getting new buttons.
I also recall a dirty 12v signal when reading threads, I think something to do with wheel loom and feedback.
I could neatly snip the 12v to the lights, temporarily connect to another feed (even direct to battery?) and test, but if not, then it would be a bit of a bodge back into that wire on the bcm.
The saga and my quest for ccs continues lol.
You honestly have no idea how happy I would be to press a button and it work haha.
Oh @Dav-Tec I fancy a remap in the NY, so maybe we can tie up a few things and kill two birds with one stone - if we get a positive lead on the issue that is!![]()
In ECU the on/off button responds as follows (at stand-still, press and hold the on/off button down):
Address 01: Engine (04L 906 056 KN)
IDE00355 Cruise Control System (CCS): status: passive/off
IDE06708-MAS14965 Cruise control switch actuation-Plausibility check of main switch: No/Yes
IDE06708-MAS14972 Cruise control switch actuation-Hardware signal main switch: No/Yes
Well, not exactly new information here - but probably just points out (still unknown) mismatch...Cruise Control System (CCS): status: Malfunction
Cruise control switch actuation-Hardware signal main switch: Yes
Cruise control switch actuation-variance adapted successfully: No
Well, your van has accumulated 136000 miles... VCDS most likely would pay for itself in not so distant future -I’m between finding a family member with an android device and getting obdeleven
That said @T6_FunBus has different clocks to you. He has the ones with no temp gauges in so not sure the symbol shows the same as I have very little experience with these clocks.
Interestingly the MFSW was available here (LHD) for EU6 T6 (MY16-19) only with fancier instrument cluster = separate temp and fuel clocks inside rev counter and speedo.Basic clocks - not sure, I read somewhere om the German forum that non or basic-MFD it still works, but may not show in cluster. I assume mine should, as I have temp, speed limit, trip 1+2 , mpg etc, I don’t believe I have speed, but maybe that isn’t a more fancy MFD but coded?
You mean these?As for the coding the 2 red line and the green line was that in the BCM or ECU?
Can you provide more details on this termination/connection.Pin 9 to light switch for +12v
You mean these?
Those lines were in VCDS Auto-Scan engine section Freeze Frame Data which @T6_FunBus posted earlier >HERE<
Re the coding - to me they look correct. However, we haven't looked into BCM adaptations - though not expecting any surprises in there.
Working hypothesis at the moment:
As there are only two communication wires - one to ECU, one to BCM - and both respond to some buttons - this suggests both those wires are good. However, for some reason either the ECU or the BCM is not happy with on/off message - either the button itself sends crappy messages or there is interference - thus the proposal to use different +12V supply. Or ground?
Well, might be too ambitious interpretation but if we look into timestamps of the faults >HERE< the BCM has manifested the fault at 17:35:54, the ECU seems to have received the manifest at 17:35:57 and finally at 17:35:58 ECU has interpreted the error message and decided not co-operate any further. Does this give us the clue to concentrate on on/off button to BCM communications - why it's not happy? View attachment 139844
Hi
I have a 2016 T6 with a steering wheel without buttons. It's CCS on stalks. I have bought a complete MFSW Polo steering wheel so I wonder if I think correctly that I can skip steps in the user manual below since I have CCS.
Point 4 I reckon goes out?
I'm a little confused on what I really need to do on points 5 and 6.
Is there perhaps someone who can explain exactly in relation to a car with CCS
4 - Get Access to the T10 connector under the battery
If you are lucky and already have CCS then you can skip this otherwise putting the wire into the T10 connector is the hardest part of the installation.
Remove the battery and the covers below it.
There you will find an enormous bunch of wires and connectors along with the ECU. Of course the T10 connector is right at the bottom.
I found the easiest way to get at it was to disconnect all the connector above it first. There are two black connectors so be careful. The one you want should have a black and yellow wire that it connects to the ECU pin 44 with. I also removed the glove box to help with the routing of the wire.
5 - Remove Redundant Wires from the Stalks Connector T41
The horn will now be operated by the LIN Bus so the brown and yellow wire has to be removed from pin 11 and insulated. This stops the horn sounding when the CCS on/off button is pressed.
If you have CCS on the stalks, and are not changing them to non CCS stalks, remove the six stalk CCS wires from pins 26 to 31 and insulate them. Remove the black and yellow CCS wire from pin 45 on the BCM connector T73b.
6 - Install the 3 Repair Wires
First Run two wires from the stalks connector T41 pins 9 and 10 to the pedal area.
If you already have CCS, reuse the black and yellow wire from pin 26 or 29 (they are connected) for pin 11 and another disconnected wire (I used the blue wire from pin 31 don't use the other black and yellow wire) for pin 11 (wires from pins 9 and 11 should now already be installed).
Pin 9 wire needs splicing into the black wire on the light switch connector. Take extra care with this one as if it fails your lights may go out.
Pin 10 wire needs splicing into the wire for pin 36 in the BCM connector T73b
Pin 11 wire goes to pin 1 of the T10 connector under the battery. I routed it through a blanked hole near the wheel arch, that I think would be used for the bonnet release cable on LHD vans. Then I drilled a hole to get to the T10 connector. The loom I had for the old CCS kit just reached the T10 connector.
Regards
Joar
