What post number you at I only got to 391 at the minute I've made some notes but not had chance to go through them yet.
Personally I'd expect the BCM to see signals to. ECU.needs to know when cruise is on and what speed etc. Bcm needs to know so it can send the messages to the instrument cluster to say CCS on and the speed so the cluster can turn on the correct signage surely?
It's frustrating and I want to get to the bottom of it. I've had another enquiry today about a wheel same age and spec as yours and I'm reluctant to do it until this is resolved.
The wiring must be ok as the wheel sends signals to the BCM and ECU. MFA and Audio buttons work and back illumination on the buttons work. This is done through LIN I'm 99% sure coding is spot on so still rattling my head with what's wrong
I’s agree, seems like it should tegister then in main control unit and body control. I got through the entire thread whilst full of turkey and junk food slumped on the sofa I did take quite a few screenshots
My overall conclusion was that everything was done and should be done as per this thread.
A few things stuck out though which may be of use to people in future:
- pin 17 on BCM is normally pinned for electric windows and door controls. It is also used for eu5 vehicles with stalk ccs
- if moving ccs to MFSW on eu6, must leave window / door control wire on 17 and pin mfsw to pin 36 then enable in coding as per original instruction in this thread or windows etc will not work (someone moved all from 17 to 36 and it caused issues?)
- if someone has ccs on stalk as well as MFSW and uses it, it will confuse the system, log an error and disable mfsw until ignition is cycled (does not matter in my case)
- if someone has MF in wiper lever and activates wheel MF will stop working also until ignition recycled (does matter in my case)
- Either way levers present ‘shouldn't’ stop MFSW from working as long as they are not used
- Horn wire should be removed from pin 11 on stalk connector prior to connecting GRA on pin 11 (actually states in instructions in this thread upon re-checking)
- Clock spring loom must be of correct type? And have all 5 wires in black connector or require modification to loom
- Setting Byte 17, bit 2 to 1 = activate GRA via MFSW
- EU5 2016 must have ccs fitted with lever only as BCM is definitely not compatible
- Without checking part no, EU6 vehicle ie Stop Start + adblue etc should have latest bcm and be compatible with GRA / CCS via MFSW
- Basic instrument cluster with no oil temp etc is also compatible
- Also should work with any non MF equiped vehicles / basic cluster without buttons on wiper stalk, just will not display function in cluster but will still be controlled via ecu
- There was a note about enabling MFD in some clusters
None of that really helps me though lol.
And to confirm up down audio, skip tracks everything works, even answer and hang up phone, also MFD controls via wheel, just CCS disabled with E45 error and will not activate on MFSW.
Merry xmas again all!
Hope santa bought you all some nice toys.
