Good. Now it's start to be exciting. You should change your coding so we can see how wheel circumference value changes.
The current wheel circumference 2111 mm implies wheel size of 215/60-17. Compared with that your wheel (235/65-17) has presumably wheel circumference 2247 mm (or it has to be coded like that).
So we need to find coding which gives close that wheel circumference.
My guess is coding "03 Distance impulse number 3..." will give wheel circumference value of 2252 mm. That would make your odometer read 6,7% more than now, and your speedo 6,7% EDIT: also more than now (overreads: if now 100, will be 107).
Change "Bit 0-3" to the above. Click "Exit", and click "Do it".
Then read the new values for "K-number IDE00842" and "Wheel circ. IDE00845" please.
The K-number (currently 22740) is number of pulses from ABS/wheel sensor for odometer to count 1000 meters. It's 48 pulses/wheel revolution.
