Glad i removed the bumper, had a heap of cleaning to do after our trip around Aus.
I trial fitted the lights, had to remove the metal clip and insert the bulb and then refit it, the rear of the fan powered heatsink did hit the back of the cap, so i grabbed a 65mm hole saw and played around a few caps extensions.
I think i'll contour the PVC Pipe end, as it will handle the heat better than the above lid cap, and it will allow me to plastic weld it.
I fitted the lights back into the van, no bulb out warning
although i can't tell much in the daylight, but i didn't notice any flicking when the engine is running.
Tomorrow, i'll sort out the PVC pipe fitting and work out how and where ill bring out the Canbus module and LED driver to fit it.
I struggled with the parking light being so yellow, so some Phillips T10 LED's and 5w resister are ordered for express post
Shame there isn't more room in the housing.
