Hi Bryn I drilled a 40mm hole in the back of the lamp access cap then cut the tops off of a suitable size aerosol can lid and hot glued this extra bump in place to accomodate the lamps fan and heat sink, cheers.
I saw that review also! It will be interesting to see what they are likeSo im going to order in the GTR Ultra gen 2 LED for my H4 tomorrow, as im not waiting for the RHD version of the MLED 2.0 to be released in 6-12 months
H4/9003: GTR Lighting Ultra 2
LED Headlight Bulbs - GTR Lighting Ultra 2 *NEW* - Headlight Revolution
As for the review, i believe it is an independent review, they sell other high end LED bulbs.
So the question im asking for those that have fitted CANbus modules when fitting the LED Bulbs, is i'm guessing that the connectors were H4??? and you fitted them inside the rear of the headlight
GTR Lighting PWM Interface Module (H4 Style Connectors)
Cheers,
Bryn
I've got some supposedly powerful leds coming for the fogs tomorrow, will be interesting to see how good they are, should make a nice infil for b roads at night whilst I work out what to do with the H4 vs H7 vs other decision in my head![]()
Yeah I noticed that, the philips never come out well in the tests on that channel, I get the impression they are more of a safe oem style update rather then being a genuine high power upgrade?Hopefully they are decent, interesting that they are the only led bulbs on the market with led chips made for cars, instead of generic led chips.
If i remember right it was a 700% increase in light compared to the Phillips LED at around 200%
I'll post a pick when i've fitted them and aligned them.
OK, LED fogs fitted, work with the cornering lights and no light out warning as of yet, done a couple of pics, one to show colour difference to halogens and two parked on a b road, fixed exposure in the camera for a genuine comparison. Comparison pics are headlights on and then the one underneath is with fogs on too.I saw that review also! It will be interesting to see what they are like
I don't think it's all about power. We are trying to replicate OEM levels of headlight performance using an LED light source that is pretending to be a bulb. OEM headlights are nothing like that. Looky here. REVIEW: Lextar LED PES headlamp module! - HiDplanet : The Official Automotive Lighting Forum
Better that than running illegal headlights though.I'm guessing that you lot using your foglights to supplement dipped beam are doing so when it's not foggy? Come on people, we're not 17 year olds in Corsas, or pensioners in Nissan Jukes for that matter.
Most of my driving is on unlit b roads, when it's empty and safe, I use the fogs as infil with the H4 main beam.I'm guessing that you lot using your foglights to supplement dipped beam are doing so when it's not foggy? Come on people, we're not 17 year olds in Corsas, or pensioners in Nissan Jukes for that matter.
I think the point is, we all know how bad the H4s are, so anything you can do to increase your safety without blinding other people isn't a bad thing, personally I'll swap the H4s out when I can afford too.Better that than running illegal headlights though.
That's not a bad idea is it! I wouldn't mind linking them together! Wonder if you can do it in vcds?I have suggested this before, but got told by Skyliner that it was still illegal use of foglights, to make a separate loom that will activate your lower bumper lights (often referred to as foglights) with main beam only. The fog light function can easily be turned off with VCDS.
I did this on my Amarok. I even went as far as swapping the headlight switch for one without front fogs.
For the money I'm pleased they were 30 quid off amazon
