Paul Hasney
Dose anyone know how to code so dipped lights stay on when in main beam.
Thanks EdModule 9, Byte 22 Bit 1 needs to be reduced by a value of 2. (Turned off)
My long code changed from a D to a B.
Only said that as there was a post recently of someone who hadn't. When playing with the code I had all sorts going on with lights and things and the first scan was always a good base to reset things to.Goes without thinking Ed
Read this post as an example of how to use vcds.Hello, you could show some example of how it is done, very grateful
I think law dictates that DRL’s should dim, as they may dazzle other road users at night. Don’t quote me, mind.Could someone tell me if it's possible to change the setting so the DRL stays on when you have the headlights on, even if they dim slightly and where I stand legally with them on with headlights, as the only info I can find just states goes off with headlights but is that a must or as a minimum?
Cheers in advance
I should really get my H7 lights coded before the events start to get dark, is this VCDS only or can Carista do it now?
I looked on the VCDS map and there don't seem to be many people near me (Chichester / W Sussex).
I think OBD11 can do all this. As OBD11 nowadays can access also BCM (module 09) submodules I can't see why not the mirror folding coding wouldn't work.Thanks for the link, didn't know that. Looks good for the lights but think I would want confirmation before splashing cash and I am not android, sadly.
Looks like the mirror folding are a VCDS only thing.
