Well I managed to fit the caravelle headlights this weekend.... and what a ball ache.... on, off, on, off!!!
All was going well, got the first unit in place, switched on the ignition and ran through a visual check of all the bulbs.... DRL’s, sidelights, headlights and main beam.... all good!
got the second unit in place and neither the DRL or sidelight were working (but as I’d put in LED bulbs I thought I’ll just rotate the fitting).... again, switch on the ignition, visual check, all good!
But when I start the engine, after just a few seconds I get a ‘bulb out’ warning light???
Just a note.... all the bulbs I’m using are PHILIPS and not cheap rubbish!
So even though the DRL is on, I’m assuming the unit doesn’t like the LED bulb, as this is when the ‘bulb out’ warning light comes on (before I’ve tried the sidelights or headlights)?
In my previous H4 unit, I was running PHILIPS LED DRL’s with no problems, so I’m a bit puzzled by this?
Is this something that can be coded out?
@Spaghetti @Deaky ??
