My one was twin H7 and Byte 18 was 69.Those VCDS entries are incorrect, they have not been updated for T6s I have scanned dozens of vans and found
H4 = 71
H7 = ?69? (Need more to confirm)
LED = 73
H4 = 71
LED = 73
It's a worth while upgrade, I used these bulbs: https://www.amazon.co.uk/dp/B00EPLCPRG/ref=cm_sw_r_cp_awdb_t1_RxVsBb4PBMKCZSorry all - new to this forum and about to buy my first t6. I want to get the upgrade done to h7 as soon as possible. My understanding is to buy the 2 headlight units from this excellent forum. But which bulbs are best to get? I want road legal but as bright and as white as possible.
Also would like the DRLs in a whiter light too
Thanks a lot!
Kev
Thanks a lot!
Kev
For the DRL i used W21W Osram LED bulb as it's quite tight in the bulb housing and some LED bulbs physically won't fit. As Ed says, no bulb warning with these.
582 Osram Long Life LED Retrofit White 12V 7440 W21W Wedge Bulb
Just confirm on what @foggy3061 has just linked here these are the exact same bulbs I used for my DRL.
Photos are at in the first few pages of this thread.Hi, so am I correct in that these don’t cause a bulb out error on the DRLs on the H7s?
Do you have a photo showing what they look like fitted and lit please?
Need to ditch those warm halogen lights for the DRLs!
In my experience I've only ever found issues when trying to buy cheap bulbs.Ah thanks. Sorry - just wanted to make sure as I’ve gone through loads of different LEDs for my wife’s DRLs and they’ve all either tripped the bulb out display, flashed at high frequency when they’re off, or failed really quickly!
I've learnt to just embrace the cost and go with osram LED. They have never thrown up errors. Never failed and the light emitted is a clean white. I've slowly put Osrams in my interior lights, reverse lights and number plate lights.
That's great, Pleased you got sorted, hopefully the future will be brighter now you've discarded those candlesA thanks to @Ed Webb for this thread was a great help, just gone from H4 to H7 myself this morning.
Thanks to @Pauly for the great service from the Forum shop super quick delivery .
Just need to ask a forum member with Vcds to do the coding for me now, but I’m in no rush.
@superflyguy straight forward job, no dramas, hour & half including T breakjob done.
If you find someone try get someone who has vagcom to change setting and allow dip/high beam on simultaneously when heads are on. This is a huge improvement over standard setting, I'd offer to do it but I'm in IrelandAnyone in the wiltshire area be able to do the h4 to h7 headlight swap and put the new bulbs in the DRLs for me? Picking up my van next Saturday and there’s no way I’d attempt it myself!
