Darkside won’t do that….Plenty with EGR coolers blanked off and DPF left in place doing its thing. I can see mine continuing to work fine via Carista.
Best time to act before you already have an issue.I've realised my egr was replaced a short while ago and I've changed the oil since so oil analysis possibly won't show much or tell me it's ok when it might not be.
I don't have any oil use, and not noticed any lack of performance so think I'll just get the tafmet kit and see how it goes
How have you been and happy new yearJust installed the Darkside Developments EGR delete plates with an Autotech Tuning remap out of the EGR valve plus engine and DSG. Instantly the engine and box feels livelier in throttle response and torque. Monitoring the oil situation. No loss in oil over the last 1000+ miles. Will send another sample to Millers soon.
Happy New Year. All good thank you. Both myself and the vanHow have you been and happy new year
FabHappy New Year. All good thank you. Both myself and the van![]()
How often do you recommend to do the millers oil testMines still going strong but I highly recommend a regular oil analysis.
Is there a Tafmet kit installed?How often do you recommend to do the millers oil test
Many thanks wayne
No there isn’tIs there a Tafmet kit installed?
I think it’s well documented that the engine is doomed unless you install it.No there isn’t
Thank you for advice it’s very much appreciatedI think it’s well documented that the engine is doomed unless you install it.
Once it’s installed, there needs to be two further oil changes in quick succession, say 2000 mile intervals, then take another sample after a further 2000 miles.
Make sure the data entered is 100% accurate.
If you know there is already a loss of compression or excessive alum / iron content then there’s a good chance it’s a waste of time. That’s why the kit needs to be in place before there’s an issue.
Will do thanks for advice it’s very much appreciatedDo 2 compression tests a couple of weeks apart. Mine was showing good compression, but on the second, it was showing really poor. He thinks it was oil that must have leaked, though, and created a seal.
