Got my heated washer jets retrofitted and all working fine, great service, thanks
@Pauly .
The fitting is pretty easy, 4 out of 10 on the T6 DIY difficulty chart. The only annoying bits were getting the wiring through the existing grommets and the bulkhead.
I can confirm that the T6 is same as the T6.1 or at least it is the same as my mates T6.1.
Heated jet on the left original frozen one on the right
They just pop out. I hooked my thumbnail in the top edge and pushed back and down.
The hose comes off by pulling the black clip across, comes out easy.
In the kit
@Pauly sent me were the units and a wiring loom terminated with the plugs for the jets. Pop out the grommet on the at the side and push the cables into the bonnet frame and out of the jet unit holes.
Hooked up the plugs and connected the hoses then clipped the jet units back into the bonnet. Part A done.
Next the cable needs to run out of the same grommet the hose follows between the bonnet frame and the wing. Luckily most of it is already there. Just snip off the end of the blank grommet tube that you took out and thread the cable through towards the hinge.
I unwrapped the tape securing the cable guide and used the spare clips along with some narrow convolted tubing. Loom tape would work fine.
Then down through the scuttle grommet into the ventilation space. To do this remove the scuttle panel. Two torq screws and pull it forward.
Sorry bad picture. The first electrical connection is the earth, Pauly sent a ring crimp, you can see it at the 11oclock position on the left earth stud. I didnt have any heat shrink so left it uncovered but will go back to it in the summer as it is in an pretty exposed location and as any aircraft engineer knows 95% of electrical snags are bad earths!!
The positive feeds can be seen going into the van through the grommet at the back right of the picture. I have other camper cables you may have more or none.
Then you can put the panel back and close the bonnet up.
As said earlier in the thread the easiest way to get power (after finding and threading the wires) is with a piggy back fuse holder. The heated jets are the lower one in the photo and the middle row is where it needs to be for 'ignition on'. Using a 2A fuse which is fine for the very low current draw. (For the curious the other one is 'IGN' feed for the Renogy DC-DC unit.
It was about -1 degrees C outside and snow on the ground when I finished this job and tested the heater jets with a food thermometer. They just come on when the ignition is on.
All working fine and I was surprised how hot they got relative to the outside temperature.
Very happy, thanks to
@Pauly for making it easy to get the parts and cables without having to leave the house.
No more dirty screen on the A9 in freezing conditions
