For Sale Heater actuator control arm - metal replacement
I appreciate your concern, you are not wrong, this would only become an issue though if the fit is greater than an a H7 h6, which given a swing of 35 degrees C would go from about 10mics interference to 1mic clearance given a snug fit at 20 degrees C. I do recommend some form of adhesive is applied to the star just to cover off the extreme heat scenarios.
That said,
I have 10off available now.
I will message the people who have messaged privately already.
Hi @N4rf! do you have any more of these available? Replaced mine with a 3D printed version, lasted 2 weeks and snapped again, a metal version sounds spot on.
Think mine has snapped again would be interested @N4rf! in one of these sick of the plastic ones now,let me know when available please
Paul
I have just sold my last two, but going to place an order for another 10 if you guys are interested.
do you still have this?
i have a t6 (2019) with an actuator arm (right handside of the van controlling hot and cold air) that is broken. Also is it universal for all the actuators?
in addition to this the actuator controlling centre vents is not working and i suspect the same problem, do you think the arm is the same? I cant find any exploded view of this system online so i struggle to find this answer.... any help be great! thanks in advance!
Can some one pin point where these arms are located behind the dash? I have the climatic control on my caravelle and it's playing up , thinking this could be the solution thanks
T6 right hand actuator control arms custom made in aluminium
I have been through many plastic ones, done the recalibration many times with all sensors reading correctly but Still breaking arms, so I had enough and designed and made my own from aluminium,
These have been tested on my own van for a number of weeks now in changing conditions, ie. Hot and cool wet weather so plenty of actuations without moving the problem else where in the system.
They are not cheap I'll admit at £32.50 posted, but machining in such small numbers I'm litterally selling them at cost price!
Can you send to QLD Australia 4655 N4rf if so what would be the cost thanks
That said,
Hi can you send to Queensland Australia 4655 and price please thanks
Hi,
Any available to buy please ?
New to the site, got my T6 Caravelle apart and reluctant to fit the plastic if breakages are that common. Can I ask why there are no limit blocks on this metal version ?
I'd also be interested in one of these please @N4rf! - my driver's side climate is stuck on max heat at the moment. Not too bad whilst it's winter but not looking to warmer weather!
Hi,
At a guess I would think that’s the issue, the limiter inside the motor servo has moved or worn and now allows over travel thus putting a lot of pressure on the limit blocks. Having none on the metal ones allows for slight over travel.
Do these fit t6.1 ? Thanks
@N4rf! has been online and looks like chosen not to respond or reply to any of the above comments so i assume these parts are no longer for sale ?
If no response is forthcoming i will close and lock this thread
Pauly
Can you tell if he’s started a new thread, strange to pull out with so much demand ?!
