Hi, I got these fault codes from obd11.
ECM/PCM Processor P06600
Engine Coolant Bypass Valve Control Circuit High P268300
Engine Coolant Bypass Valve "A" Stuck/Open P26AB00
I clear the faults but they come back after about 20km or so.
Is this the correct part to replace?
www.proxyparts.com
Your help is appreciated.
Regards.
Water pump Volkswagen Crafter - 2N0965567C
New Volkswagen Crafter Water pump Part number 2N0965567C Months of warranty 12 mo., Year of construction 2024, Classification code N2, Type of engine Diesel Common Rail (Turbo), Engine capacity 2,000 cc, Gearbox 6-speed, Odometer reading 10 km Offered by Klein Gunnewiek Autodemontage &...
Regards.
