I get a VCDS error when trying to test lift pump. The auto-electricians obd tool is unable to activate the lift pump.Please elaborate a bit.
a) Did you run VCDS > Engine > Output test > Fuel pump electronics - and didn't hear the pump (cycling on and off every four seconds)?
b) Did you run VCDS > Engine > Basic Settings > Test of Transfer Fuel Pump (running the pump continuously) - didn't hear the pump?
More details
[T6_measured] 01-Engine - Built-in test for Transfer fuel pump
A quick DIY way to test fuel lift pump's basic functionality. The test takes advantage of engine's fuel high pressure sensor (in fuel rail). Running the lift pump continuosly makes the pressure eventually "leak" through high pressure pump and can be detected by fuel pressure sensor. As a side...www.t6forum.com
