As said earlier in the thread absolutely superb but do consider the long version which I personally prefer.
Thanks for the advice, I can't find that one anywhere online - is it a case of just calling minster direct?
Yes just give them a call they are very helpful peopleThanks for the advice, I can't find that one anywhere online - is it a case of just calling minster direct?
I agree - I've found them super helpful.Yes just give them a call they are very helpful people
We went for the long because it covers the scuttle so it stops draughts through the air vents, stops the scuttle filling with leaves, snow just slides off and doesn’t build up, it covers the wiper blades so the rubber doesn’t perish in the sun and you don’t get any light leakage along the bottom.I agree - I've found them super helpful.
@Nigel W - what's the big benefit of the long version? On most of the thermal screens I've seen, the wipers sit on the bottom, which I presume helps hold it in place... obviously this wouldn't be possible with the long version?
Super helpful. Thanks @Nigel W![]()
Hi @Adaptive - they actually haven’t arrived yet. Let down by deliveries as they tried to deliver pre 9am before anyone was in the office. I tried to rearrange and then called up on Friday and they had marked it as “return to sender”.Hey bud, have you tried your motor blinds?
HiggidavIn our experience External are better to minimise condensation.
Which ones where you referring to in this post? Did you get them, if so what do you think?Are these external windscreen thermal covers as good as they say, and do the wind deflectors obstruct fitting? Cheers.
