Hi All,
First post, so please be kind!
We have a 150W solar panel with an MPPT controller, and a 110ah leisure battery (all fitted by a camper converter, both brand new). Based on a couple of short trips without electric hookup, I don’t think the panel / MPPT are charging the leisure battery correctly - but have never had a solar panel before so want to get some other opinions as to whether what we are experiencing is “normal”. We are going back to the converter with this, but it would be really useful to see how others with a similar setup are getting on, as this will aid us in our conversations with the converter.
To make things easier, we decided to perform a controlled test to get some specific data and evidence (our MPPT controller has a Bluetooth connection to an app, so we can see current readings, and also download data for 30 days).
Panel: FLEXi SUN – 150W Flexible Solar Panel | CampervanCulture.com
MPPT: Midsummer Energy
The test we performed is as follows:
Check MPPT Bluetooth readings at 07:00, 13:00 and 17:30
Check MPPT data for the entire 24 hour period
Test results – individual readings:
For that 24 hour period, the MPPT controller recorded the following key points:
Even with the van parked in good sun, at 22 degrees or so for 10 plus hours - the leisure battery was down to 60% charge (from 100% at 7AM), in a little over 10 hours. Over that period, the Bluetooth app reported a total output of 50 watt hours from the solar setup (which seems ridiculously small to me - adding just 4ah, back into a 110ah battery).
We based all our calculations of which panel to buy on this article: Solar Power - The Camping and Caravanning Club. In there is suggests that 150w panel should produce up to 1,000wh on a summers day, and 120w or so on a winters day. Lets be kind and say our sunny test day was in the middle of those points – and even based on that assumption, our setup should still have produced around 600wh or so in the day, as opposed to 50wh as it did?
Question:
What experience do others have with 150 watt panels? Is what I am seeing “standard”? My expectation was that on a lovely sunny day, the solar setup should run a fridge (on medium setting, full of cold food) for 10 hours without consuming 40% of the leisure battery’s charge? If what I am seeing is right, I cannot for a second understand why anyone (including me) would every buy one!
Comments and thought much appreciated.
- Start with leisure battery 100% charged.
- CRX50 fridge turned on at 7AM (middle setting, and full of cold food).
- No other electrics turned on.
- Camper parked in / facing the sun for the entire day. The test day was 17th September, which just happened to be the best day we had in September: Conditions on test day were as follows:
- Wall to wall sunshine (no clouds at all)
- Outside Temperature: 18 to 22 degrees
- Camper time directly in sun (upwards of 10 hours).
Date / Time | Solar Watts | Solar Voltage | Solar Current (amps) | Battery Volts | Battery Current (amps) | Battery State | Battery % charge | A/H remaining |
17/09/2020 07:00 | 0 | 20.25 | 0 | 12.65 | 0 | bulk | 100.00% | 110 |
17/09/2020 13:00 | 0 | 13.03 | 0 | 12.38 | 0 | not charge | 75.00% | 82.5 |
17/09/2020 17:30 | 0 | 12.6 | 0 | 12.24 | 0 | not charge | 60.00% | 66 |
- Max battery charge (start of day): 13.27v
- Min battery charge (end of day): 12.09v
- Time in Bulk (when its actually charging): 4 hours, 28 mins.
- Total produced Watt Hours: 50wh (which I am assuming is just 4 Amp Hours, so very very low!)
Question:
