I have this also and I believe @mopardave also has these symptoms. It sounds as if there is a definite issue here.hi folks
So we have had our new T6 150 manual highline for a week now and have noticed two problems
Juddering when cruising along
The fan coming on after a short journey example just after popping to the shop on the way to work
Thanks in advance
Does it judder all the time or every now and then?
It happens every now and then but when it does happen its like what CRD says
Oh, that's interesting, I'll keep an eye on that. I wonder if by disabling the gear indication (if possible through VCDS) would help?Well on monitoring it always happens to us when the van thinks you should change gear (the guidance bit in top right hand corner of dash) mainly between 4-5th if you have been in that gear a while. We had the AA out and he said if it gets worse to get it booked in at the dealer its just getting it there as its a day away from work for us! let us know how you get on
Van is booked in for investigation a week on Friday coming. Today it exhibited a new strange behaviour- stopped at traffic lights, no s/s activated and began to idle really roughly. Engine was cold and tacho was showing just under 1k mark. Starting to annoy me a bit now, hope the investigation uncovers something and not just told 'couldn't find anything wrong mate'
Mine has been doing this over the last few days. Last night it did it after a 2 1/2 hr non stop run, temperature fine. Then this morning a short run (10mins) and did it. Then this evening after a 15 minute run the fan was on again. As others said, just like a plane taking off. It's a bit embarrassing if this is how it's meant to be??If I only make a short round town journey, the fan overruns nearly every time and occasionally smells really hot. It's amazing how loud the fan is!
