Yes, the voltage in bulk charge phase will rise slowly to about 13.5v at about 98% SOC then rapidly to 14.2v at 100%, then when the MPPT goes into float mode it'll drop down to 13.5v.
14.2v is the fully charged voltage.
The bulk charge is never 14.2v throughout the bulk stage, if that's what you mean? Although I don't think you do.
See here in my system:
I don't know how you've got your charging profile configured, but the fogstar drift recommended parameters are 14.2v in bulk and 13.6v in float - i.e. the voltage should step down when the battery is fully charged. This is pretty standard in a multi-stage charging setup. It just means that monitoring for a full battery by looking for the highest charging voltage doesn't tend to work because the charge voltage has usually stepped down by then.
It's worth checking your charging setting just in case, because the maximum voltage fogstar recommend for float is only 13.6v so if you have somehow got it set to something higher, there's a chance it may not do the battery any good.
