Heater? Have you checked it still works?Now need to find what the random beeping is?!
As linked before, simple inline on/off switch on that signal wire near the DC-DC.On the dc to dc switch, what do I do with the ignition wire that is currently in situ? Just lash?
Or is it worth me just not wiring a switch? And leave dc to dc to do its thing
If you do want a switch (as @ginkster says I'd not bother for now and see if you want one later) you'd just need to put one into the ignition wire.On the dc to dc switch, what do I do with the ignition wire that is currently in situ? Just lash?
Fridge…??Heater works
I’m not sure why but the app says that is intended for maintenance purposes only.Or, it's about a 20 second job to turn it off in the app!
Might be different on the older Orion chargers, mine just says "Charger will be disabled and battery will stop charging".I’m not sure why but the app says that is intended for maintenance purposes only.That’s why I did a switch which is about as simple as it gets! 2 min job.
Ah, yeah, they’ve changed the wording on the new one. Makes more sense.Might be different on the older Orion chargers, mine just says "Charger will be disabled and battery will stop charging".
If I wanted to put in a switch I'd put one into one of the switch blanks in my dash so I can access whilst driving, so carpet out, dash part out.... Nah. I'll just use the app! Which I can also use from anywhere thanks to my Cerbo GX![]()
I’ve got it…..it’s the low fuel warning! Get the wife to fill up asap!I’ll do some listening tomorrow for the beeeep
Seat belt warning. Won’t cause a beep if left off. I did the same.Re beep, I’d left the little clip sensor under seat centre off as I was going to get back into work but needed to drive van.
Would that cause a beep? What is that cable?
