Examples but maybe cheaper elsewhere:View attachment 253943
Just waiting for wiring to land. Can someone drop me some links to recommended ‘isolator/ rocker switches’ if I go down the route of manual control?
Thanks again.
Amazing thank you!Examples but maybe cheaper elsewhere:
Victron LB Isolator
or
Blue Sea LB Isolator
Switches for DC-DC or AMT , also available from Halfords for a couple of quid.
Isolator for solar panel
Box for solar isolator
I used Climbingvan (now NOHMA) and they were excellent. They have some fantastic information on their site too - well worth a read.
And quick q, on my diagram, presume the ignition live is the wire from the scr to the fuse box? And that is where switch will go.Examples but maybe cheaper elsewhere:
Victron LB Isolator
or
I know these are REALLY basic questionsAnd quick q, on my diagram, presume the ignition live is the wire from the scr to the fuse box? And that is where switch will go.
Do these little rocker switches just get wired in line with spade connectors or do they also need grounding as they have a led? Again, bear with my Luddite level of knowledge.
You need to identify the ignition wire with your multimeter to make sure you have the right one. It should be fuse at the end furthest from the DC-DC to protect the cable in case of a short. Sorry, I didn’t mean to link to LED switches, I’d just get simple non-led ones which go in-line with spade connectors. The switch then goes on the ignition wire to break that signal when you do not want the DC-DC running. You need to turn off the auto-sensing on the Orion otherwise it will run regardless of the switch position.And quick q, on my diagram, presume the ignition live is the wire from the scr to the fuse box? And that is where switch will go.
Why would you want to manually disable the Orion? Have I missed something?You need to identify the ignition wire with your multimeter to make sure you have the right one. It should be fuse at the end furthest from the DC-DC to protect the cable in case of a short. Sorry, I didn’t mean to link to LED switches, I’d just get simple non-led ones which go in-line with spade connectors. The switch then goes on the ignition wire to break that signal when you do not want the DC-DC running. You need to turn off the auto-sensing on the Orion otherwise it will run regardless of the switch position.
Make sure you read the Victron instructions carefully. You must follow the correct order when connecting things up and doing the initial setup.
I have a clamp meter I bought and don’t know how to use, would this be easier than multimeter to identify the ignition wire?You need to identify the ignition wire with your multimeter to make sure you have the right one. It should be fuse at the end furthest from the DC-DC to protect the cable in case of a short. Sorry, I didn’t mean to link to LED switches, I’d just get simple non-led ones which go in-line with spade connectors. The switch then goes on the ignition wire to break that signal when you do not want the DC-DC running. You need to turn off the auto-sensing on the Orion otherwise it will run regardless of the switch position.
To prevent it charging the LB every time you start the van. If one is driving the van regularly but not using the LB for long periods it allows you to keep the LB at a decent storage voltage. Only valid for lithium and clearly depends on your usage.Why would you want to manually disable the Orion? Have I missed something?
I’d use a multimeter personally, or the multimeter part of your clamp meter if it has one. Also issues as mentioned by Stay Frosty.I have a clamp meter I bought and don’t know how to use, would this be easier than multimeter to identify the ignition wire?
Oh, I think the red wires are for use with the fuses, got that. (So redundant in my (your) plan). But the extra black?So the following is what has landed from simply split charge website.
I understand the two red and two black big wires to left are for the DC to DC input/ output and for grounding to chassis.
The big fuses in my plan I presume are redundant as I am going to reuse the in situ wire and simply reduce fuses down to 50.
The thin gauge wire and all small bits I presume are for the Amt 12-2.
So my question is….what is the two thick red wires and one thing black wire with ring terminals for?
Many thanks!Also, if you fit those 2 basics and something isn’t working then you’ve only really got a couple of things to check.
Add in the ablemail and the other kit one item at a time because you don’t have the confidence to check the whole install if something isn’t working. Do it in small chunks and each time you add something you are starting from a known good. Less stress.
Forget the mains charger until the end. It’s only an issue if you plug in to EHU. So don’t plug into EHU.
With solar and that new battery you should last for days anyway.
Was that a pre-made kit for something? The thin cables will be ok for the AMT once you have crimped the spade connectors that come with the AMT.So the following is what has landed from simply split charge website.
