They are both needed to level.What does the back one do??
Unplugging either would work, but I think the front is easier to get to.They are both needed to level.
Glad its worked as a temp fixOk.. so got it lifted, full locked the wheel and managed to reach the plug connector. Dropped it out and the only thing I have is sandwich bags and cable ties to keep it dry!! It has worked! The lights now don’t hit the trees on acceleration and dive to the floor on braking. Great temp fix!
cheers @Skyliner33 for the info! Worked a treat. I’ll let you all know what comes of it when fixed.
So I haven’t drove the van at night since having the SoLows lifted but I will give it a go and seeWell I haven't but I’ve found a fix!! Another member also had this issue. @RyanGerry do you still. We’d pointing the the right direction? Check this out.
LED Headlight Adjustment
hoping someone can help, my vans on air and at a low cruising height if I’m stuck in traffic and pull forward it flicks the headlights up and pretty much flashes the car in front. Also found driving around it’s going up and down all the time. Found quite a bit information about adjusting them...www.t6forum.com
Can I ask what you changed on VCDS ? As I’m having the same problem on airInitially it needs tweaking with VCDS to calm the floating down. Once that has stopped I found adjusting the headlights fixed this issue.
