LifeOS have this mentioned.
Technical Information - LiFOS
but I've emailed this to them :
Hi guys
We have a lifeos 68 battery.
the Bluetooth unit seems to have locked up?
we have tried the APP on various android and iphone devices all with the same result.
please can you advise on how to reset/reboot the Bluetooth module.
many thanks
but the listed email address . . .
Your message to
hello@lifos.co.uk couldn't be delivered. -- hello@ wasn't found at
hello@lifos.co.uk.
BUT . . . . . I've just called the tech number 01684774000 and had a great techie chat with Kevin from LifeOS.
Hes given us some great feedback and thing to try.
First off is the look for the Bluetooth light on the top of the battery (under the plastic sticker on the top, it will be very dim in the daylight so do it in the dark) - the light should be on/flashing if the bluetooth is alive.
second is confirm the battery voltage is in range with a separate volt meter . . . .
third is to try the APP on android and IOS devices and numerous ones to discount an issue with any device and 100% prove it battery related.
fourth is too try this reset procedure "TOTALLY FLATTEN THE LIFEOS BATTERY" ie run a load from it until its flat as flat can be, this will help to reset the internal BMS and module.... Newt is "FULLY CHARGE" the battery using a smart charger via EHU until 100% full . . . . then retest the APP.
On this occasion I've found the LIFOS team very approachable, helpful and very willing to help. Kevin did say that he had received the (my) tech help request via the website i had sent and that i was 330 or so in the list that he was working though from tech support requests over the weekend.
Kevin has asked for a feedback report on the above issue . . . . so
@Ian28 please can you follow the instruction above and report back here:
detail full issues you are having:
what devices you have tried the APP on:
what is the status of the bluetooth LED:
current voltage of battery:
then full drain battery:
then fully recharge battery:
