Greetings.
I’ve recently had the orange coil light flash up on start and a stop start error.
On checking I had the following errors:
P064C00 - Glow Plug Control Module
P172400 - Signal for starter lock, short to ground
I cleared these a couple of times and would run fine and but now they are back and with more errors!:
03046 - Battery Regulation control module, no signal / communication
02252 - Generator, no signal / communication
03158 - Information Electronics Control module 1, no signal / communication
U01400 - Lost communication with body control module
03022 - Local databus 4, error in electrical circuit
Most are clearable, apart from Signal for Starter lock.
Not really sure where to start. The battery is charging, and was replaced and coded (new serial entered) earlier this year. Van starts and runs fine apart from stop start is disabled when the signal for starter short to ground persists, sometimes that will clear and no errors and stop start works fine.
Could this be the green / yellow lin wire look damage people have reported before?
Any other suggestions on where to start?
Thanks.
Thanks.
