Moving a sargent Ec155 power unit
Tommy B
Hi, I need to relocate my sargent unit as it's in the way of some units I'm getting fitted later this month.
Just want to double check with anyone in the know with my process.
  • Measure out units dimensions on the floor and panel.
  • Switch off leisure battery isolator switch under drivers seat
  • Make sure sargent box is off.
  • Unclip wires from sargent box
  • ‘Dry fit’ Sargent box to new panel and see where it can go to fit in units.
  • If happy - screw it onto the panel where you want it.
  • Put holes in the back for wires to run through.
  • Unscrew large panel, locate wires and feed through to new location.
  • Clip these back into the sargent box
  • Refit smaller panel
  • Refit larger panel
It seems straight forward enough but wanted to make sure I'm not missing anything as it's the first time I've touched any of the vans electrics.
Photo to show where the current unit it and new location (and my dogs arse...)
Update: It wasn't as straight forward as I had hoped :laugh:
I'm stuck on how to pass the big clips with multiple cables (pictured) through the middle part of the van. The smaller cables have been pulled through fine but these seem to not fit.
Is it a case of having to trace every wire unhook / clip it and pull it through the other way (towards the big clip) then re-attach and organise.
I was hoping that this wouldn't be the case as I'm not too confident I'll know exactly where everything needs to go.
