I’m not sure what rating the panel is. And I would still want EHU chargingWhat rating is your current panel?
You also need to consider EHU charging. You will need to disable the "charger" in the Sargent - it won't charge a LiFePo
If you mostly do off grid and charge from driving or solar then that may not be an issue but otherwise you'll need to add an EHU charger, maybe a Victron, and you'll need to find a place to wire that into the EHU mains (downstream of the breakers)
I will start researching all these bits I need to buy and dare say I will have more questions.
Thanks for all your help so far.
