Well I’ve been looking for a better quality solar panel, I’m put off buying another eBay 12 volt panel after my broken unit and also the semi flex panels after seeing how a lot of people are having problems with them.
(The Solbian semi flex panels are around the $1000 mark here for 100 watts in Aus!!!)
So I started to look at what is available locally in a hard panel, there is a lot of crap out there!
I can get my hands on a LG 330 Watt solar panel with will work with my Votronic 350 MPPT, as it can handle 350 watts and a 50 VOC.
Now, does anyone know a calculation to work out the amps from a 40.9 voc to 14.4 volt charging rate..
I’m aware the MPPT with take the higher volts and produce more amp’s
But the question is how much more???
Surely it cant be as easy as 330 watts % 14.4 volts = 22.9 amps
Anyhow, if anyone can advise me, on what amps I should be seeing then that would be great.
Cheers,
Bryn
LG Panel Specs
Maximum power at STC (Pmax)
330
MPP Voltage Vmpp (V)
33.7
MPP Current Impp (A)
9.80
Open Circuit Voltage Voc (V)
40.9
Short Circuit Current Isc (A)
10.45
Module Efficiency (%)
19.3
Operating Temperature (°C)
-40 ~ +90
Maximum System Voltage (V)
1000
Maximum Series Fuse Rating (A)
20
Power Tolerance (%)
0 ~ + 3
*STC (Standard Test Condition): Irradiance 1000 W/m2, module temperature 25 °C, AM 1.5.
The nameplate power output is measured and determined by LG Electronics at its sole and absolute discretion.
The typical change in module efficiency at 200 W/m2 in relation to 1000 W/m2 is -2.0%
Cheers,
Bryn
LG Panel Specs
330
33.7
9.80
40.9
10.45
19.3
-40 ~ +90
1000
20
Power Tolerance (%)
0 ~ + 3
