Fill and shower points
First test didn't go well
I'd not used a proper Whale elbow connector and the one I did use off Ebay didn't have the grooves in so the pump pressure pushed the fitting out.
So I replaced that and at the same time replaced the last 3 feet of the tank fill pipe with a flexible pipe to allow me to fit the units either and ensure the fitting didn't move or come lose with any movement whilst driving. If I did it again I would probably just use the flexible pipe for everything rather than all the Whale fittings but they came with the tank kit I got.
I also had issues with the drain tap not sealing!!
