Excellent. Thanks for the fault codes - a kind of as expected... the van isn't happy with the LEDs.
I'm afraid we have to skip the massive 480 character string for now. It would have been easy if you would have retrofitted both front and rear LEDs
- we have the data for that combinations.
Below are so called "Leuchte" sets which need to be tweaked that van "understands" the new lights correctly.
The
new values are from a van with factory installed front and rear LEDs. The current values are from your van.
The T6.1 electrics are much more complex than what it was on T6. As can be seen below there is a full data set for each individual lamp - here one for the left parking/side light, another for the right.
So whenever ready - do the adaptation changes above.
Before entering into adaptations you possibly need to use a security code.
VCDS > Select > 09-Cent. Elect. > Security Access (input 31347)
Adaptation > ....find & tweak the above adaptations...
Please report the findings, fault codes in 09., do the lights work any better?
Clear the faults in 09 and recheck them - any change?
For the brake lights it would be similar set -
And again separate sets for indicators, fog lights, reverse lights - that's in the next episode.
