So at nearly 5 days we are still at 12.68v.
With the fuses removed we were at 12.38v after 4 days so clearly different.
Looking at the wires on the positive terminal, we have 4 (plus the one to the voltage monitor so 5 in total). Difficult to see them all in a photo but here's the best I could do.
Two have yellow sheaths on the end and two red (the one coming front wards is the voltage monitor). I think the yellow ones are thinner wires. It's difficult to trace them of course as they run inside the paneling.
The fridge is supposedly on fuse 1 of the first bank (15A) and although I have no reason to doubt this I will do as you suggest when I reconnect and make sure it goes off with the fuse pulled. However, I doubt it's the fridge as there is no indication of, any kind that it's on when we turn it off.
So, theory is that the wires on the plus terminal are ctek, victron, fuses bank 1 and fuses bank 2. If this is right though, where is the parasitic drain? I guess I need to know if the two fuse banks are daisy chained or whether the 4th wire is a mystery connection.
Could I prove this by using a resistance tester on the battery plus terminal and pushing the other probe into an empty fuse holder? Thinking on, I guess I can only prove individual wires to the fuse banks versus daisy chain by taking off the positive terminal wires and testing individually. Any thoughts?
If there are individual wires to the fuse banks, don't we have a bigger mystery as there is no way to drain the battery with the fuses pulled?
Again, I greatly appreciate your assistance with this detective work.
